Activity Forums Apple Final Cut Pro Legacy Green screen fottage for web
  • Green screen fottage for web
    Posted by Zach Smith on October 2, 2007 at 11:07 pm
    Hi I have shot some green screen footage that is going to be used on a clients website, the web developer I am working with is using flash and would like to get the files from me with a transparent layer, I have already keyed out the footage and am wondering how to deliver this to the web developer so that they can put it on the site without the background showing, any help would be great thanks in advance.
    David Bogie replied 18 years, 11 months ago 2 Members · 1 Reply
  • David Bogie
    October 3, 2007 at 1:54 pm
    > I have already keyed out the footage and am wondering how to deliver this to the web developer so that they can put it on the site without the background showing, any help would be great thanks in advance. < Export the clip using QT Conversion, not the sequence, using Animation codec set to millions of colors+, the PLUS SIGN is the alpha. The main problem is that FCP will export the sequence, or the clip, using the setting sor the sequence or the native clip, which is probably DV. It is NOT Animation unless you set it up that way, which is doubtful. Just a warning, be prepared to do this several times. You must remain calm and patient. Your Web/Flash guy probably thinks he knows more than you do but you don't know anything about Flash and he's probably on a PC anyway which hopeless complicates your ability to get along with each other if he's Macintolerant, too. bogiesan
