Activity Forums VEGAS Pro Green screen botched it.
  • Green screen botched it.
    Posted by Kayley Grace on May 24, 2013 at 2:45 am
    I have a new green screen. Follow the process of ensuring I was white and the screen was black.
    Then put the image as background I wanted underneath the video image and the result is the image sitting behind a black screen as opposed to the background disappearing.
    I follow these instructions https://www.youtube.com/watch?v=GzQ0MhC6FnM
    This is the start of the green screen image. I hope i’ve put these in right.
    6050_image69.jpg.zip
    This is what i’ve ended up with.
    What am I doing wrong?
    6051_image202.jpg.zip
    John Rofrano replied 13 years, 3 months ago 4 Members · 12 Replies
  • 12 Replies
  • Don Cobble
    May 24, 2013 at 3:12 am
    looks like you have your track order reversed (the wrong one on top)
    PC
    I7 2.8 Ghz 8GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    3-4 TB HD
    Vegas 10 64bit & Vegas 11 64Bit & Vegas 12 & Adobe Production Premium CS5.5.2 & Avid Media Composer 5.5
    Camera
    Sony EX1 shoot in 1920×1080 30P
  • Kayley Grace
    May 24, 2013 at 8:20 am
    I have the video on the top and the image as the background on the bottom. Isn’t that the correct way.
    The blue you can see is the background, then there’s me. The black you see is where the green screen was and is meant to be invisible only it’s stayed solid black.
  • James Houghtaling
    May 24, 2013 at 4:30 pm
    Do you still have the “Show mask only” button checked?
    My Hardware:
    Core i7 2.67GHz; Nvidia GTX580, 12 gig RAM Win7 64bit.
    My Software:
    Vegas Pro V11 with Boris Continuum Complete 8, VASST Ultimate S; Bluff Titler; AE5; PhotoPaint and other stuff.
  • Kayley Grace
    May 25, 2013 at 12:55 am
    Hi James thanks for the question – it’s unclicked.
  • John Rofrano
    May 25, 2013 at 2:35 pm
    Can you post your images so that they display in the post?
    I don’t download random ZIP files (sorry).
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Kayley Grace
    May 26, 2013 at 2:15 am
    Yes of course John That’s what I thought I was doing only it didn’t seem to work that way.
    How do I do that? If I click on the file upload and then add the file it takes me to a post, do I add the details and click post?
  • John Rofrano
    May 26, 2013 at 2:08 pm
    [Kayley Grace] “How do I do that? If I click on the file upload and then add the file it takes me to a post, do I add the details and click post?”
    Once you select the upload button it will give you a window like this:
    Then cut and paste the Embed URL into the text of your post. It’s important to cut and paste the Embed URL and not the Link URL.
    ~jr
  • Kayley Grace
    May 27, 2013 at 3:53 am
    Ah ok I realized I was clicking on the wrong upload button.
    what i started with in sony vegas – this is an image of the video i am working on
    What I ended up with. Where the green screen is it’s black and sits on top of the blue background.
  • John Rofrano
    May 27, 2013 at 11:43 am
    Are those snapshots of the Vegas preview? I’m trying to understand why there are black bars on the sides of the original shot and also on the keyed shot but to a lesser extent. Was the video recorded at a 4:3 aspect ratio?
    How do you have your tracks composited? You did something wrong because normally the background would show only where there is green but your video actually shows outside the green screen which leads me to believe this was shot in 4:3 and then you composited the tracks together somehow (which is not required).
    Try this:
    1. Start a new project.
    2. Add the green screen footage to the project as a new track.
    3. Add the Chroma Key plug-in to the event and key out the background.
    4. Add a track below with the background image you want
    You should see something like this:
    ~jr
  • Kayley Grace
    May 28, 2013 at 7:32 am
    Yup John I agree that is what it should look like only it’s not.
    I have started a new project, have gone through all the steps.
    Added Chroma keyer to the video by dragging over to the video window.
    Used the colour selector to select the right green
    Clicked show mask only then
    Changed the threshold to get the black and white split.
    Unclicked show mask only.
    Added by back ground video below the green screen video
    Then where the green screen is now black is what stays so it doesn’t become a transparent background showing the below image it stays as a black background.
    Does that make more sense?
