Activity Forums Cinematography Green Screen Advice- Best Camera
  • Green Screen Advice- Best Camera
    Posted by Pierre on November 30, 2005 at 2:50 am
    Excluding HD. Which camera would work best with greenscreen work? I’ve heard that the IMX and XDCAM aren’t great due to NOISE.
    Sony PDW-530 1000 Lines Digital Power HAD EX [16×9] XDCAM
    Sony MSW-900 1000 Lines Digital Power HAD EX [16×9] IMX
    Sony DVW-700WS 850 Lines Digital HYPER HAD 1000 f-8 [16×9] Digital Betacam
    Sony DVW-700 850 Lines Digital HYPER HAD 1000 f-8, Digital Betacam
    Sony BVW-D600 850 Lines Digital HYPER HAD 1000 f-8, BetaSP
    Sony BVW-D600WS 850 Lines Digital HYPER HAD 1000 f-8, BetaSP
    Panasonic AJ-SDX900P DVCPro50 24p/30i DVCPRO50
    Ed Kukla replied 20 years, 7 months ago 4 Members · 5 Replies
  • David Jones
    November 30, 2005 at 2:11 pm
    Are you going to be in a studio environment where you can use a separate VTR or uncompressed NL workstation to record, or do you require a camera/recorder for field recording?
  • Pierre
    November 30, 2005 at 3:42 pm
    I won’t have access to a deck. I’ll be in the field.
    Michael
  • David Jones
    November 30, 2005 at 11:17 pm
    What format VTRs do you have available to play back your tape on, would be a consideration before selecting a camera.
    Also what budget do you have including lens?
    Also, how are you going to light your green screen in the field to give you a good key?
  • Paul Thurston
    December 9, 2005 at 6:27 pm
    Hi Michael,
    If you can, usa a Digital Betacam camcorder setup to record in 10-bit 4:2:2. Use soft TUNGSTEN lighting for the Greenscreen and foreground image. If that is not possible, use soft Daylight and make sure forground and background light levels are similar and that no shadow is seen on the greenscreen.
    -Paul Thurston
  • Ed Kukla
    December 29, 2005 at 7:26 pm
    Digibeta or the SDX900
