Activity Forums Apple Final Cut Pro Legacy Green Render Bar Woes
  • Green Render Bar Woes
    Posted by Doug Perry on March 14, 2011 at 6:15 pm
    Hi, I have a clip that I needed to speed up so I did a ‘Fit to Fill’ and FCP adjusted the clip fine with a ‘green render bar’ and everything looks great! When I render the sequence my footage looks like garbage bouncing back and forth from clear to a slight blurriness to it… sort of pulsing back and forth.
    The sequence and footage match (DVCPro50) so I’m not sure what’s up.
    Thanks for your help.
    Doug
    Jeff Greenberg replied 15 years, 6 months ago 2 Members · 1 Reply
  • Jeff Greenberg
    March 15, 2011 at 1:43 am
    Try to pick these specific speeds: 25%, 33%, 50%, 66%, 75% etc.
    Weird Fit to Fill speeds are going to have odd problems with frame blending.
    Or run it through Motion and set the Retiming to Optical flow. That will definitely be smooth.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
