Activity Forums Lighting Design green reflection from projector
  • green reflection from projector
    Posted by Maxim Moisseev on March 21, 2010 at 8:44 pm
    Hi!
    Haven’t found a suitable forum for this question. Hope you can help me.
    Many times I encounter the same problem – white light from videoprojector lamp, when reflected from black surface, becomes green! But only from specific angle. If I move 30 degrees right or left, reflection becomes white again.
    This is disturbing my brain. What can I do again this green light? WHY is it green?
    http://www.transscreen.ru – clear projection films and touchscreen.
    Maxim Moisseev replied 16 years, 5 months ago 3 Members · 3 Replies
  • Hunter Mossman
    March 22, 2010 at 5:38 pm
    You may want to try posting this in the Corporate Video section.
    Good luck!
    Hunter Mossman
    Director of Photography
    http://www.huntermossman.com
  • Mark Suszko
    March 22, 2010 at 8:44 pm
    Is the black screen really black? And why is it black? I suspect this is a polarization effect. Also, white is relative and depends on the white balance you set.
  • Maxim Moisseev
    March 22, 2010 at 8:52 pm
    I mean any light color close to bright white, reflecting from black surface (plastic, dark glass, chair varnish) becomes green.
