Activity › Forums › Apple Final Cut Pro Legacy › Green needs render.
  • Green needs render.
    Posted by Gracias on August 18, 2005 at 6:46 am
    Hello,
    Quite curious to know on my timeline if I put some C.C. fx on my clip which shows green on the Timeline. Does it require rendering before outputting to tape.
    Thankx
    Gracias
    Gracias replied 21 years, 1 month ago 2 Members · 2 Replies
  • Shane Ross
    August 18, 2005 at 7:29 am
    The Green render bar above the clip on the timeline means that you can preview it realtime, at a lower resolution. This will need to be rendered before you output. Alway render everything before you output.
  • Gracias
    August 19, 2005 at 5:26 am
    Hello,
    I was sure of Light Green which is on the timeline needs to be render. Do I have to do the same even for the Dark Green before outputing to the tape.
    Regards
    Srini
