Activity Forums Apple Final Cut Pro Legacy Green Horizontal Line
  • Green Horizontal Line
    Posted by Daniel Corcoran on June 19, 2008 at 9:27 am
    I am importing dv files into FC5 that have been ripped using Handbrake/ mpeg streamclip- my problem is when I load the files into the viewer/canvas/ timeline there is a green horizontal line running down on the very far right side of the screen. It happens in all the windows when I’m watching the clip. When the clip is paused it remains on the right side of the clip. Any help would be greatly appreciated.
    Cheers
    Daniel
    Eric Johnson replied 18 years, 3 months ago 2 Members · 1 Reply
  • Eric Johnson
    June 19, 2008 at 5:21 pm
    If i’m understanding your problem correctly, what you have is a digital frame line from your source material, which i’m assuming was DVD converted to DV. This is fairly common, in my experiaence. to eliminate/ avoid you will probably have to blow up your frame to hide your right frame edge, probably 2 or 3 percent.
    hope that helps.
