Activity › Forums › Apple Final Cut Pro Legacy › Green Freeze
Green Freeze
Posted by Chris Wasmer on October 1, 2008 at 5:50 pmRunning OS 10.5.2, FCP 6.0.3, QuickTime 7.4.5, 4 Gigs RAM.
Working on a DVCPRO HD project at 23.98.
For the past month no problems, but now every 10 – 20 minutes, the canvas goes green and then FCP freezes — “FCP not responding.”
I tried trashing preferences and repairing disk permissions, but this didn’t help.
Media is on a FireWire 800 drive with about 1/3 free space left.
Help! Thank you.Chris Wasmer replied 17 years, 11 months ago 3 Members · 18 Replies -
Jeremy Garchow
October 1, 2008 at 6:17 pmDo you have any capture card or anything to monitor your footage with?
Chris Wasmer
October 1, 2008 at 6:43 pmYes. I am using a Matrox MXO. I disconnected it and still have the same problems.
Jeremy Garchow
October 1, 2008 at 6:48 pmHmm. That green is usally a corrupt file somewhere.
Do you have still images in your project?
Jeremy Garchow
October 1, 2008 at 9:09 pmHmm. That could be the culprit. How much footage do you have? The easiest way to check for corrupt footage is to make it all offline and then reconnect a handful of files at a time. Total PIA, but it tell you if one of those files went bad.
Jeremy
Chris Wasmer
October 2, 2008 at 1:17 amI tried “offlining” the suspect media, but it didn’t solve the problem.
So I made a new project and duplicated my most recent sequences into it. I then deleted a suspect sequence, and the problem went away!
I still have media on the drive from this corrupt sequence, and this media is in almost all of my duplicated sequences.
So it seems that a corrupt sequence was screwing up the project. but i’m not sure…
My new project has a lot less items in it. So maybe this helped?
