Activity Forums Adobe Premiere Pro Green flashing in imported clips
  • Green flashing in imported clips
    Posted by Mark Farrington on October 7, 2012 at 5:23 pm
    I’m new to Premiere so I’m not sure what to do about this issue.
    I have several avi’s I’m trying to edit together for a project but when I import them into Premiere they have random frames of solid green that creates a flashing effect. These errors show up in the source frame before I drag it to the timeline and do any rendering.
    Outside of Premiere they playback without error in every player I have access to and I used the bad frame finder tool in virtualdub which showed the entire clip as good.
    The only thing I can think of is that Premiere is having an issue with the Cineform codec used to encode the source videos.
    ETA: I’m using CS6
    Anup Speed123 replied 13 years, 11 months ago 3 Members · 5 Replies
  • Axel Arzola
    October 7, 2012 at 9:20 pm
    I had the same issue working with 7D footage on previous versions of Premiere, but really is just while you are editing because as you said there will be no problem after you export your edit.
    You could try a different codec, and also try installing a codec pack (K-Lite has always worked fine for me).
    Also try to use your original files if possible, maybe that could help.
    Axel Arzola
    http://www.facebook.com/arzolafilm
  • Mark Farrington
    October 8, 2012 at 3:56 am
    After doing some more digging apparently my issue is that there is no Cineform plugin for CS6.
    The work around seems to be copying the Cineform plugins from CS5 into CS6’s plugins folder but not having CS5 I’m unable to do so.
  • Axel Arzola
    October 8, 2012 at 2:07 pm
    I got CS5.5 on Mac. Tell me the exact name of the plugging and I can email it to you.
    Axel Arzola
    https://www.youtube.com/user/axelandkretel
  • Mark Farrington
    October 8, 2012 at 9:49 pm
    I need the contents of C:Program FilesAdobeCommonPlug-insCS5.XMediaCoreCineForm
  • Anup Speed123
    October 10, 2012 at 7:20 am
    Free up the memory where all your Cache files are getting saved………
    or if u want to change the location then goto
    EDIT-preferences:
    1.switch off the auto save feature
    2.select scratch disks and change the locations
    once this is done then switch off the software and shut down the PC and retart the pc as well as the software and reimport the FILE u will not get the green flashing video this time
