Activity › Forums › Avid Media Composer › green dots in middle of clips
  • green dots in middle of clips
    Posted by Tel Jaba on December 7, 2010 at 6:57 pm
    working on a project that I got from another editor, I haven’t worked on Avid in a long time so I am refreshing my memory now, but I noticed that some of the clips in the sequence have a little green dot in them and when I click on the effect editor I see that it is a “motion effect ediot” the speed seems normal and it says 100% so what do these dots mean and why are they there?
    Daniel Huber replied 14 years, 11 months ago 6 Members · 6 Replies
  • Michael Hancock
    December 7, 2010 at 6:59 pm
    Are you working on Media Composer 5? If so, these are motion adapters that are converting the footage from one frame rate to another. Avid automatically adds them if you open footage from a project with a different frame rate. Or the editor took interlaced footage and made it progressive with motion adapters.
    Michael Hancock
    http://www.oswaldcommunications.com
  • Tel Jaba
    December 7, 2010 at 7:26 pm
    thanks a lot for your replies Michael
    yes I am working with MC 5.0 project was edited on 4.x (not sure)
    I had to repair a;;l bins by the way and some of the sequnce bin wouldn open and they couse Avid to quite!!
    so what do you suggst I shoudl do about this green dot Michael?
  • Kris Anderson
    December 8, 2010 at 6:02 am
    Render it.
  • Job Ter burg
    December 8, 2010 at 7:01 am
    Before you render everything, are you by any chance working in 25fps? If so, you may just have 25p footage in a 25i/50i project or 25i/50i footage in a 25p project, and then you should be able to just switch your project to the right format.
  • Kris Petersen
    October 13, 2011 at 3:01 pm
    Ok, I’m having a similar and yet baffling problem.
    Only some of my clips have green dots. They were all shot 720P, 29.97; the sequence and project settings are the same. All of the clips were shot consecutively, same day, no change in the camera settings. It just randomly changes, first half of the sequence has dots on all the footage, second half does not, except on the last transitions (cross dissolves into the filler). Those transitions have dots.
    Any suggestions? I’m confused. I understand that rendering will get rid of them, but why are they there in the first place?
    Thanks!!
  • Daniel Huber
    October 14, 2011 at 4:47 am
    If you are seeing green dots in the middle of clips when they are in a sequence they have motion adapters on them.
    This means some clips are a different frame rate! You can find this out by adding the FPS column to the bin through text view.
    This is how you can mix and match frame rates. It is done automatically by the editor, and it is based on your projects settings at creation.
