Activity Forums Apple Final Cut Pro Legacy green circle with check mark…
  • green circle with check mark…
    Posted by Chris Balogh on May 5, 2009 at 6:03 pm
    I accidentally pushed some button in which when on the timeline a GREEN CIRCLE WITH A CHECK MARK is on top of the monitor where it shows me zebra lines…how do I get rid of it?
    thanks
    Marc Jeffrey replied 17 years ago 6 Members · 6 Replies
  • Chris Poisson
    May 5, 2009 at 6:06 pm
    That is the range check and it means everything is okay. You turn it off in the view menu. I alwaya leave it on in the canvas.
    Have a wonderful day.
  • Chris Balogh
    May 5, 2009 at 6:07 pm
    excess luma ha…
  • Tom Wolsky
    May 5, 2009 at 6:08 pm
    Control-Z is the keyboard shortcut you pressed. It toggles it on and off. You probably meant to press Cmd-Z.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Kevin Monahan
    May 5, 2009 at 6:22 pm
    Must be an ol’ Windows guy. 😉
    BTW, if you have an upward arrow and the green check mark, it means your luma level is optimized. Now ya know!
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Bret Williams
    May 6, 2009 at 6:57 am
    Or shift+z. I use that all day and often hit ctrl z by accident.
  • Marc Jeffrey
    September 6, 2009 at 4:46 pm
    I have a lower third graphic that was created in After Effects and is now in a QuickTime Movie format. When I import it into FCP it plays fine as a stand alone preview. However, when I play it on the time line to play over a video, it plays very shaky. Is there something I can do to remedy this? I made sure it is fully rendered.
    Marc Jeffrey
