Activity › Forums › Avid Media Composer › Great Way to Prerp material for backup Windows
  • Great Way to Prerp material for backup Windows
    Posted by Alex Udell on August 16, 2006 at 12:27 am
    Hi Guys…
    Ever want to consolidate a set of material for archive, but don’t have another drive hanging around?
    Here’s a way to work around it…
    Go to your media drive and make a new folder for archive (I’ll use “M:/archive folder” for this example)
    Now go to Start Button
    Got to RUN and type CMD to open a command prompt…
    Choose a drive letter that is not being used by the system (in this example I’ll use Q:)
    Type:
    subst q: “M:/archive folder”
    Now open my computer…
    You’ll notice the addition of a new volume for the M Drive (it will have the same label of your media drive not the flder you chose)
    this acts as a temporary lettered shortcut to that folder…
    Avid will see this as a volume…
    now you can go back to avid and consolidate all of aprojects media and material to that new M: volume, essentially moving it all out of your Avid media folder…
    when you are done…
    go back to the dos prompt and type:
    susbst Q: /d
    this removes the temp drive letter assignment…
    enjoy!!
    Alex
    William Busby replied 20 years, 1 month ago 2 Members · 2 Replies
  • William Busby
    August 19, 2006 at 6:12 am
    It might be a good idea to correct your typos for those who haven’t done this before. Especially when it pertains to command prompts.
    Just a suggestion
    Bill
  • William Busby
    August 19, 2006 at 6:24 am
    also… the most important should be noted:
    the only time Avid should be open is when consolidating. All the other steps Avid should be closed.
    Bill
