Activity Forums Avid Media Composer great system, bad avid
  • great system, bad avid
    Posted by Iksoviet on September 23, 2005 at 2:55 pm
    I just got a new workstation and installed AVXpro 5.12. I have a great workstation (see spec below) but I keep having these errors like:
    -When I played the seq the monitor frezees, though the audio is playing.
    -I can
    Diego Villalba replied 20 years, 12 months ago 5 Members · 6 Replies
  • Iksoviet
    September 23, 2005 at 3:23 pm
    I
  • Michael Phillips
    September 23, 2005 at 9:21 pm
    You are a little light on the RAM, anothr 1/2 Gb minimum… perhaps that will help as well.
  • Satesh Ramjattan
    September 23, 2005 at 10:08 pm
    TO SCRUB AUDIO, YOU MUST TO HAVE CAPS LOCK ACTIVATED.
  • Rob Stemm
    September 23, 2005 at 11:34 pm
    If you have CAPS lock on the audio will scrub. Also if you hold shift down while moving the playhead you will hear the audio scrub.
    Hope that helps with the audio issue
  • Iksoviet
    September 24, 2005 at 2:15 am
    I
  • Diego Villalba
    September 29, 2005 at 12:05 pm
    I have a great system, and a bad avid too.
    SISTEM CONF
    WINXP SP1
    PENTIUM 4 3.0GHZ
    1GB RAM
    TWO HD: 1 of 80GB (SYSTEM) AND 200 (MEDIA) BOTH SATA
    NVIDIA GeForce 6200 para 256 MB(WITH THE LATEST DRIVERS)
    My problem has to do with exporting with quicktime… I can scrub audio and the realtime play is OK, but I found that we have tha same brand of video board… does anybody know if it is our problem? My Motherboard is an ASUS P5GDC Deluxe…
    I was looking at avid.com and I couldn’t find any restriction about NVIDIA boards…
    Thanks.
    bye.
    diego
