Activity Forums Adobe After Effects Expressions Gravity w/ Markers
  • Gravity w/ Markers
    Posted by Matthew Tully on November 5, 2007 at 9:27 pm
    Hi All,
    I’m looking for a way to simulate gravity turning on. After a few seconds of animation, where objects float in zero-g, all the sudden gravity is introduced and the objects fall off the screen. I tried keyframing this but I can’t figure out the velocity of the objects. I would imagine that this can be accomplished by linking gravity properties to markers or map them to time. Any ideas?
    Russell Cox replied 16 years, 1 month ago 3 Members · 6 Replies
  • Dan Ebberts
    November 6, 2007 at 12:12 am
    Give this a try:
    g = 1000; // gravitational constant
    if (marker.numKeys > 0 && time > marker.key(1).time){
    t = time – marker.key(1).time;
    y = g*t*t/2;
    value + [0,y]
    }else{
    value
    Dan
  • Matthew Tully
    November 6, 2007 at 3:19 pm
    Thanks Dan! Does the trick as usual.
  • Russell Cox
    August 5, 2010 at 2:07 am
    I’m trying to accomplish a similar effect but I put this expression in my position layer and it’s not working, does it need a dummy control layer or a slider control? How do I control when the gravity effect occurs?
  • Dan Ebberts
    August 5, 2010 at 2:55 am
    Just put a layer marker wherever you want it to start falling.
    Dan
  • Russell Cox
    August 5, 2010 at 12:31 pm
    Sorry, it’s still not working. Let me review; alt click on stopwatch in static text layer, paste expression, click on keyframe marker. Preview and nothing happens. What am I missing?
  • Russell Cox
    August 5, 2010 at 1:17 pm
    Got it! First time using expressions triggered by markers, thought it was triggered by a keyframe. Thanks for your help.
