Activity Forums Maxon Cinema 4D grass and wind
  • grass and wind
    Posted by Dan Roth on November 27, 2008 at 11:43 pm
    i created a grass material using hair as described in the help manual. i then placed a wind particle deformer in the scene. how do i get the wind to injteract with the grass?
    dan
    Elias Huch replied 16 years, 7 months ago 4 Members · 3 Replies
  • Brian Jones
    November 28, 2008 at 2:33 am
    is the Wind Shape big enough to include the grass (or just set it to Unlimited)? For more realism try adding a Turbulence too (also Unlimited).
  • Adam Trachtenberg
    November 30, 2008 at 3:37 pm
    You have to drag the wind object into the hair object’s Forces box and set the mode to include. It will work better if you set the hair object’s Dynamics>Gravity setting to a positive number.
  • Elias Huch
    February 3, 2010 at 6:39 pm
    Can you elaborate as to where the forces box is located in the interface? I’m having trouble finding it.
    Elias Huch
    Motion Graphics Designer
    Reelvizion Productions
