Activity Forums Avid Media Composer Graphs in Timewarp effect
  • Graphs in Timewarp effect
    Posted by Toby Hinger on October 16, 2009 at 12:42 am
    Hi guys,
    When in the effect editor for Time Warp, I can’t seem to zoom far enough out to see key frames above 2100% speed. I’ve dragged the little slider as far as I can.
    Any ideas?
    T
    Toby Hinger replied 16 years, 11 months ago 2 Members · 2 Replies
  • Ra-ey Saleh
    October 16, 2009 at 2:44 am
    Yeah, there’s a limit I believe on the slider.
    You can use the RW/FW keys to hop from one keyframe to the other theen simply type in your number in the speed box.
    If you really need to see your keyframe, hold down CONTROL + ALT and click in the Graph. You should get a ‘hand’ that will let you pull the graph down.
    Ra-ey
  • Toby Hinger
    October 16, 2009 at 4:22 am
    The control-alt thing is what I’m after, though it’s a pity you can’t zoom all the way out.
