Activity › Forums › Media 100 › Graphics turn to B/W
  • Graphics turn to B/W
    Posted by Jeremy Rowell on December 13, 2006 at 6:37 pm
    On one of my media 100’s If I have two graphics back to back or layered, they turn B/W for a couple of frames. Then I get the error titles need to be rendered. This are very basic graphics with just our “Bug” in the lower right static. Any Ideas how I could clear this issue up?
    Jeremy
    Jeremy Rowell replied 19 years, 9 months ago 2 Members · 2 Replies
  • Floh Peters
    December 13, 2006 at 6:44 pm
    In Media 100 i, the Graphics tracks graphics are overlaid using the hardware framebuffer. If you have 2 graphics close together (I think less than a second) the system cannot load the graphic clip quickly enough into the framebuffer and will give you the realtime error message. A workaround (if you have long graphics and you don
  • Jeremy Rowell
    December 13, 2006 at 7:00 pm
    That makes sense, Thanks. We already have an HD unit, and are looking to get another as soon as the new version is released that is compatible with the new mac. For now, I’ll just have my editor keep them a second apart, or render the split graphic. We usually dump around 40 10-30 second promos on the time line and add our station bug to them, so rendering would take up too much time. Spliting every graphic would tend to get tedious too, but it will work for other projects on that machine. Thanks for your help.
    Jeremy
