Activity Forums Adobe After Effects Graphics Template for Wiping In Multiple Lines of Text
  • Graphics Template for Wiping In Multiple Lines of Text
    Posted by Max Schapiro on September 21, 2019 at 12:23 am
    Howdy gang- apologies if my lack of experience and knowledge about how AE (and creative cow) works is off-putting, but I’m in a pickle.
    I’ve been doing weekly work for a client for a video series- in this series, text appears on screen (often in multiple lines) by linearly wiping on with a bit of edge feather, line by line. The text appears in boxes of varying sizes.
    How I’ve been doing this up until now is, in premiere, having each line be a separate text on its own track in the timeline, using the Linear Wipe effect with a feather on each, and trying to line up the ending of one line’s wipe with the beginning of the next line’s, and repeating that for up to 5 lines of text.
    However, even if copying and pasting these multiple tracks of text, changing the size of all of them to fit different sized boxes between different episodes causes the alignment of the Wipes to go out of sync. This makes what, conceptually, should be a simple process much more time consuming, having to adjust each track for each instance of text multiple times an episode.
    I’m looking for a way to streamline the process significantly. If anyone has any other suggestions I will obviously take them, but for now I think my best option is a Motion Graphics Template.
    In that case, I think to sum it up what I need is tips on how/expressions to make this template (or templateS, if one should be made for one line of text, one for two lines, one for three, etc).
    Ideally it should be able to sense the length of a line of text, wipe (with feather) to the end of that line, and then immediately begin the wipe on the next line of text at the same speed and so on and so forth.
    Essentially its just a fancier Typewriter effect- able to detect the length of the content and procedurally reveal it, just with that feather and wipe.
    Any ideas will be greatly appreciated
    Tomas Bumbulevičius replied 6 years, 11 months ago 2 Members · 5 Replies
