Activity Forums Blackmagic Design Graphics Tearing
  • Graphics Tearing
    Posted by Bruce Fraser on May 12, 2008 at 4:56 pm
    Just got the Multibridge Pro. When the playhead is stopped in the timeline graphics and video are tearing, it’s not tight and crisp like you would think in an SD 8 bit timeline. As the video plays the graphics are perfect. I have all the RT settings set to the highest settings in the sequence.
    I never had this problem with the Aurora Igniter..?
    Bruce
    MacPro 8 core 3Ghz
    10g RAM
    RAID
    Boris Graffiti
    Live Type
    Motion
    FCP 6.0.3
    Bruce Fraser replied 18 years, 4 months ago 3 Members · 4 Replies
  • Kristian Lam
    May 14, 2008 at 6:50 am
    Hi Bruce,
    When you mention graphics, are they generated from a plugin for stills on top of the video layer with alpha?
    I’ve not come across this issue so it will be good to find out more information. For example, what kind of timeline is it? 10-bit PAL? 8-bit 1080i60?
    regards
    Kristian Lam
    Blackmagic Design
  • Bruce Fraser
    May 14, 2008 at 8:08 pm
    I have an Apple 8bit SD timeline. Using LiveType or Boris Grafitti. Alpha over ntsc video.
    Bruce
  • Massimo Croce
    May 15, 2008 at 4:27 pm
    it ‘s because you have check single field when paused in BMD preference. this mean that when the playhead is stopped you watch only one field in video out..
  • Bruce Fraser
    May 16, 2008 at 4:44 pm
    Thanks for the hint. In the Decklink system prefs there’s a checkbox that says: Remove field jitter when video is paused.
    Kind of counter intuitive but unchecking that box made the graphics perfectly clear.
    Bruce
