Activity Forums Adobe After Effects Graphics/ Resolution Pixel Aspect Ratio?
  • Graphics/ Resolution Pixel Aspect Ratio?
    Posted by Iann Mcgill on April 2, 2007 at 6:33 pm
    Okay… I am not sure where this message belongs, so if you can point me in the right direction that would be great!
    I create an animation in After Effects, Resolution “Best”. Import that into Avid at 2:1, lower field first, everything looks great. Then when going to Adobe Encore to create a DVD, if all of the footage in my sequence hasn’t been up res-ed to 2:1 then it seems to distort the area’s where my graphics are. It almost looks like it compresses the screen alittle bit. We use Sorenson squeeze to encode our video into an .mpv format. Any solutions? Does all the video need to be at the exact same resolution? Is there something I’m doing incorrectly in AE, Encore, Sorenson Squeeze or Avid?
    Thank you for your help!
    Steve Roberts replied 19 years, 5 months ago 2 Members · 1 Reply
  • Steve Roberts
    April 2, 2007 at 7:20 pm
    For NTSC,
    The AE comp must be 720×480 D1/DV non-square pixel ratio: the DV preset, in other words.
    Render without doing any stretching.
    Everything else after that, in all apps should be at 720×480, D1/DV (non-square) pixel ratio.
