Activity › Forums › Apple Final Cut Pro Legacy › Graphics moving…….
Graphics moving…….
Posted by Tarik Sykes on June 14, 2007 at 2:08 pmAfter compressing????/ Why does this happen? It looks good on the timeline but once I compress the graphic will shift up and be a little bigger then other graphics.
John Pale replied 19 years, 3 months ago 6 Members · 10 Replies -
Tarik Sykes
June 14, 2007 at 2:25 pmIts a talking head interview and and I have graphics in the lower 3rd. style. There is a logo next to his name. It is a circle next with the companies initials in it. The top of the circle is lined up with the top of his name…. when I compress , the logo shifts upward! I just shifted it down on the timeline and I’m compressing another one now. Hope it works..,…… Thanks
Ernie Santella
June 14, 2007 at 2:31 pmAre positive your graphics are the same frame size as your timeline? I make that mistake once in a while. I render out a Livetype title and it’s in a different resolution as the timeline.
Ernie Santella
Santella Film/Video Productions
http://www.santellaproductions.com -
Jeff Nelson
June 14, 2007 at 2:34 pmLet’s see if I can post some shots. Here is what it looks like in the timeline:
and here is what it looks like after using compressor to make a 720p version:
Note that the graphics of the name look like they were not compressed, they seem to be the original size in 1080 and so they’re messed up. This is a bit of a disaster for a one-hour show with a bunch of these.
Any suggestions?
John Pale
June 14, 2007 at 2:56 pmDescribe your workflow…how did you get your 1080 footage into Compressor?
Reference Movie?
Self-Contained Movie?
Send To Compressor? -
Jeff Nelson
June 14, 2007 at 2:59 pmEdit in 1080p hdv, then File, Export, to Compressor, then when I change the framesize, this is what I get. I’m going from the timeline, not from a rendered quicktime movie, where I guess I probably wouldn’t have this problem. But that’s an extra step. Don’t know why compressor isn’t changing the size of the titles, just the video picture.
Soreyrith Um
June 14, 2007 at 4:46 pmTry export using Quicktime conversion, then select the format you want. Or nest your timeline in a 720p timeline, then export from there.
John Pale
June 14, 2007 at 6:39 pmThe “Send to Compressor” command does not use your sequence render files (your lower third is a rendered effect), but rather renders directly into the codec you are exporting to.
This can slightly improve quality when exporting to MPEG-2 for a DVD, but in this case it appears to be tripping you up, as it is not accounting for HDV’s anamorphic frame size correctly, in addition to the resize to 720p. I think thats why your graphics look stretched.Best to take the extra step and export a Reference Movie, drag that into Compressor and see how it goes. Reference movies only take a few seconds to export.
Jeff Nelson
June 14, 2007 at 8:44 pmThanks for the explanation. Makes sense. Will try this workflow, reference movie first.
John Pale
June 14, 2007 at 11:16 pmYou should still file a bug report with Apple, using the Provide Feedback link…
Thanks for all your years of service setting up Mariano Rivera for the Yankees.
