Activity Forums Apple Final Cut Pro Legacy Graphics interlacing
  • Graphics interlacing
    Posted by Darwin Phillips on May 9, 2009 at 4:22 pm
    I’m having interlacing problems with a spot. The footage was originaly shot HD at 23.98 square pixels. The Graphic overlays that I’m using was made with no codec at 29.97. Miscommunication on the producers part. The original sequence was created at 23.98 to match the footage. But In SD NTSC. Video is clean and plays fine. But the Graphic overlay is interlaced. After discovering the frame rate issue, I created a seperate sequence at 29.97 and placed the graphic on the time line. Plays Perfectly, so I took one shot and placed it in the timeline, played fine as well. but when I Composite the two and rendered, the graphic interlaced. Any Ideas?
    Darwin Phillips replied 17 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
