Activity › Forums › Apple Final Cut Pro Legacy › Graphics DV MPEG-2
  • Graphics DV MPEG-2
    Posted by Alexander Gao on February 2, 2007 at 9:26 pm
    I have a project in NTSC-DV. I am trying to go to DVD, and therefore I compress straight off of the fcp timeline into MPEG-2 files that I load into DVDSP. I know that in this compression, I should keep the fields set to lower first, but this makes graphics look bad. Is it ok if I just compress the intro (a 2 minute sequence of graphics) with progressive frames, and compress the part with actual video to lower field first and then just slap these two MPEG-2’s next to eachother in the DVDSP track timeline?
    Alexander Gao
    “When the revolution happens, I’ll be leading it.”
    Uli Plank replied 19 years, 7 months ago 3 Members · 2 Replies
  • Chris Borjis
    February 3, 2007 at 1:16 am
    no.
    It all has to be interlaced.
    DV to mpeg2 is going to look less than perfect no matter what you do.
  • Uli Plank
    February 3, 2007 at 8:06 am
    Apart from that, DVDSP is not flagging progressive flags correctly. You can check it with ReStream (PC only).
    Regards,
    Uli
    Author of “DVDs gestalten und produzieren”, a book on professional DVD-authoring in German.
