Activity › Forums › Apple Final Cut Pro Legacy › graphics coming to edge
  • graphics coming to edge
    Posted by Arty Gold on November 16, 2005 at 2:06 pm
    hi…i have a quick question
    i’m using a graphic in fcp as an alpha chanel…
    basically it’s a transparent see-thru type of effect..
    the problem i’m having is sometimes the graphic goes off the screen..,
    and sometimes it looks like it’s being cut off…it’s not going past the safe title so to speak…
    any way to fix this or is it just plumb luck where the graphic ends up ?
    Arty Gold replied 20 years, 10 months ago 3 Members · 4 Replies
  • Jerry Hofmann
    November 16, 2005 at 2:54 pm
    Post what the file format is of the graphic, and how large it is in pixels, then also post what the sequence setting you are putting it in is.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Arty Gold
    November 16, 2005 at 3:30 pm
    the picture is a photoshop image
    it is 720×486 (produced the correct way in photoshop to make it fcp compatible)
    basically i took the image and razor cut it in my sequence to create a motion type wobble effect.
    however like i said sometimes the image is getting cut off…it stops at at the graphic safe title…
    other times it goes full bleed right to the edge.
  • Gary Hughes
    November 17, 2005 at 3:13 am
    If the image is 720×486, and if you are moving it around to do the wobble effect, then you are revealing the edge of the image during the move. Create your image larger than default if you are planning to do any movement in FCP. Sounds like you’re moving it to the title safe border, so I’d create it 20% larger in Photoshop and you should be fine in FCP. Only create graphics at 720×486 if you plan on NOT moving them at all in FCP.
    Hope this helps,
    Gary
  • Arty Gold
    November 17, 2005 at 12:55 pm
    super !
    that makes sense…what an idiot…
    the more i learn and the more i use fcp the dumber i get !
