Activity Forums VEGAS Pro Graphics card error “Unmanaged Exception (0xc0000005) “
  • Graphics card error “Unmanaged Exception (0xc0000005) “
    Posted by Byron Leung on January 25, 2012 at 8:50 pm
    I really need help on this whenever I try to render something out using Vegas 11, the rendering always crashes at 20-30% and I get this error:
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 11.0 (Build 520)
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:\Windows\system32\atioglxx.dll
    Fault Address: 0x112AB154
    Fault Offset: 0x0098B154
    Fault Process Details
    Process Path: C:\Program Files (x86)\Sony\Vegas Pro 11.0\vegas110.exe
    Process Version: Version 11.0 (Build 520)
    Process Description: Vegas Pro
    I have looked up the fault module file and it was something for my graphics card so I tried re-installing my graphics card drivers and updating them but it did not work.
    I have tried rendering on Vegas 10e and Vegas 11 and I have gotten the same error message every time
    Any solution please?
    Nigel O’neill replied 14 years, 7 months ago 4 Members · 4 Replies
  • John Rofrano
    January 25, 2012 at 10:47 pm
    You would probably have to work with Sony directly on that as only their developers can really debug their stack traces. I would try installing the drivers from the manufacturer that you purchased the card from rather than from ATI as those are the drivers the card was actually tested with.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Byron Leung
    January 26, 2012 at 1:57 am
    Thanks for the quick reply!
    I have tried installing many different versions of the drivers for my graphics card but not one of them solved my problem.
    I am going to try re-installing my OS and see if that helps.
    Thanks again for your help!
  • Steve Rhoden
    January 26, 2012 at 11:57 am
    Or in the meantime, disable the GPU support in Vegas
    so you can get your renders done.
    Steve Rhoden
    (Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
    https://filmex-creative-media.blogspot.com/
  • Nigel O’neill
    January 27, 2012 at 3:13 am
    Byron, you could try rolling back your drivers to the ones Windows shipped with i.e. take it right back. If that works, I would leave it at that.
    If it does not, I would stick to WHQL certified drivers obtained from manufacturers web site. I would avoid obtaining them from Bit Torrent sites or similar, and I would avoid beta releases.
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
