Activity › Forums › Apple Final Cut Pro Legacy › Graphics Card config recommend
  • Graphics Card config recommend
    Posted by Sam Goldstein on November 22, 2010 at 3:32 pm
    Thanks in advance for any consideration…
    I am asking this in this forum because this is a question for a system that primarily uses FCP (7.0.latest). Aside from Squeeze and a handful of A/V utilities, FCS is the everyday work for this system. I need to get another solid year out of this workstation.
    I have a Mac Pro 1, 1 with 8mb of RAM. Kona Lhi and a FW800 card installed. I recently eBay’ed myself an ATI Radeon HD 4870 512MB (for Mac) to increase the systems performance. I am specifically hoping to address issues rendering Magic Bullet Looks on higher quality formats… “Graphics Hardware does not support rendering… yada, yada…”
    My question is what’s the best config for the cards I have, including the stock NVIDIA GeForce 7300 GT 256MB? Should I simply replace the old graphics card with the new, or should I use both? and if so in what slot config? I am driving two monitors… a 23″ Cinema Display HD and a 20″ Cinema Display. If I just use the ATI card, I think I’ll need a Mini DisplayPort to DVI adapter for the 2nd display.
    Thanks so much for any advice.
    -Sam
    MacPro 2×2.66Mhz, 8GB Ram, AJA Kona LHi
    Michael Gissing replied 15 years, 10 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    November 22, 2010 at 5:45 pm
    Here’s a decent read on the subject of upgrading graphics cards for your older mac…
    https://barefeats.com/wst10g6.html
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Michael Gissing
    November 22, 2010 at 8:34 pm
    The ATI is the recommended card for FCS, particularly Color. I don’t think you can run two graphics cards.
    There have been a few posts here in the last six months about graphics cards as many want to run Adobe CS5 on the same machine, but CS5 is recommending NVidia. A quick search of the forum might give you some further tech opinions.
