Activity › Forums › Adobe After Effects › Graphics Black Spot!
  • Graphics Black Spot!
    Posted by Alex Bond on June 21, 2005 at 11:18 am
    Help – I’ve just finished bolting together a sequence of end credits. The format is credits over a simple scrolling graphic, created in photoshop and after effects to be then imported into m100i ver 8.2.1.
    Problem – I get black spots on one field on some parts of the graphic when i render the movie.
    The graphic is two tone with large areas of beige colouring (is it too bright perhaps?)
    Any ideas?
    Alex Bond replied 21 years, 3 months ago 2 Members · 4 Replies
  • Aharon Rabinowitz
    June 21, 2005 at 12:25 pm
    are you seeing black spots on a TV screen or your monitor. If it’s only on the TV screen, you may be out of safe color range. If that’s the case, try this:
    Here’s a trick I’ve used successfully in controling safe colors, which may help here…
    For every piece of footage you bring in apply the Levels effect and set the following:
    In Black: 16
    In White: 235
    On another adjustment layer on top of your final comp use the same effect with the following settings:
    Out Black: 16
    Out White: 235
    Now I suspect that you could just make one final layer with 1 levels effect with all 4 settings, but I am not sure about the order of theeffect properties, so I don’t know if it’s a good idea.
    The point of using this is to get rid of hot colors – you will see a difference on the computer screen- things get a bit duller, but you will barely see a difference on the TV, and the untrained eye will not notice a thing.
    If it’s also on the monitor that you’re seeing this, than it beats the heck out of me… Sorry. Can you describe in more detail or post a screen shot?
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Alex Bond
    June 21, 2005 at 12:42 pm
    It’s on the monitor too, even when you just play back using quicktime.
    I’ve got round the problem by rendering it using the Media 100 codec but now i’ve got a bad video frame error (probably a slow or full drive) so I’ll have to try again i think, i’ll give those settings a go.
    Unfotunately I can’t post a screen shot as the series hasn’t been aired yet but the black spot looks like an underscore and appears only on one field at a time (and i’ve only got one incidence in a 30 second clip – still a broadcast failure though)
    thanks for the help
    Alex.
  • Aharon Rabinowitz
    June 22, 2005 at 8:58 pm
    Sounds like currupted footage. Check it outside AE.
    Aharon Rabinowitz
  • Alex Bond
    June 23, 2005 at 8:20 am
    Fixed it by rendering using video compressor in AE. Footage was only photoshop graphics which i made myself.
