Activity Forums Adobe Premiere Pro Graphics appearing TOO transparent in premiere
  • Graphics appearing TOO transparent in premiere
    Posted by Claudia Canales on November 29, 2017 at 4:27 pm
    I have this weird issue that I have no idea how to fix…
    I export graphics from after effects, and i premiere they’re way too transparent… I’m exporting in pro res 4444 rgb+alpha… tried also exporting in animation with an alpha channel and it does the same exact thing… I don’t know what playback or preview setting in premiere i’m not getting right.
    Playback settings
    sequence settings
    Andy Patterson replied 8 years, 9 months ago 3 Members · 6 Replies
  • Jon Doughtie
    November 30, 2017 at 6:07 pm
    If you could post a screen shot or capture that would help. Not clear on how the transparent part of the image can be “too” transparent.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2017.1 (as of 8/2017)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
  • Andy Patterson
    November 30, 2017 at 8:59 pm
    Select Maximum bit rate and see if that helps. Also try using GPU acceleration turned on and off and see if you notice a difference.
  • Claudia Canales
    December 4, 2017 at 1:15 pm
    In After Effects:
    In Premiere
  • Claudia Canales
    December 4, 2017 at 1:17 pm
    I changed the graphic… (i know its not the same) just to clarify… but the transparency difference is still the same.
  • Claudia Canales
    December 4, 2017 at 6:29 pm
    FILE –> PROJECT SETTINGS –> GENERAL:
    have to change the renderer to “Mercury Playback Engine Software Only”
    instead of “Mercury Playback Engine GPU Acceleration”
    …fixed it. 🙂
  • Andy Patterson
    December 4, 2017 at 11:51 pm
    I have let Adobe know about the issues between GPU acceleration and CPU acceleration for a long time. On a positive note it is now 2017. In the year 2019 or 2020 8 core and 16 core CPU will be the norm. You may not need an expensive $350.00 GPU in the not so distant future.
    [claudia canales] “FILE –> PROJECT SETTINGS –> GENERAL:
    …fixed it. :)”
