Activity Forums Adobe After Effects Graphic ranking animation technique
  • Graphic ranking animation technique
    Posted by Rafael Braz on November 6, 2019 at 4:59 pm
    Hey, lately I’ve seen a lot of this kind of video:
    https://youtu.be/RSuloaATQRA
    Does anyone one knows if this is made on AE and/or how is it made?
    Thanks in advance!
    Graham Quince replied 6 years, 10 months ago 2 Members · 1 Reply
  • Graham Quince
    November 9, 2019 at 6:02 pm
    It’s entirely possible to do this in After Effects, using keyframes and expressions and a bit of manual tweaking, but my guess would be that this is using one of the many oven-ready templates / info graphic web-based software.
    To make in after effects, I’d create a solid, and use another solid as an alpha mask. Then I’d use a slider to set my value and this expression on the x position of mask solid, to create the growing/shrinking bar:
    input = effect(“Slider Control”)(“Slider”);
    inputLow = 0;
    inputHigh = 100;
    outputLow = -100;
    outputHigh = 100;
    linear(input,inputLow,inputHigh,outputLow,outputHigh)
    I’d then duplicate my layers, making sure the mask layer is parented to the bar layer, and manually keyframe the swapping of vertical positions.
    http://www.YouTube.com/ShiveringCactus – Free FX for amateur films
    https://shiveringcactus.wordpress.com/ – FX blog
