Activity › Forums › Adobe After Effects › graphic plugin advice
  • graphic plugin advice
    Posted by Jacqueline Cooper on December 6, 2008 at 5:00 am
    I am about to embark on an escapade to do text motion graphic for overlays as fast as physically possible and have been asked to suss out which plugins I will be needing to create such fx as might be seen on an old nintendo games for instance. borders that go from static stills to lighted edges, flipping letters, that kind of thing. So far I have been looking into Image Lounge, Digital Anarchy, Particular, and echospace as possible solutions, but I am a bit out of the loop and would love any input as to cool texty graphicy stuff you guys tend to use regularly (not to complex, think sega genesis 🙂 )
    Thanks in advance for your advice!
    David Bogie replied 17 years, 10 months ago 2 Members · 1 Reply
  • David Bogie
    December 6, 2008 at 4:13 pm
    > to do text motion graphic for overlays as fast as physically possible<
    If speed is your primary goal, plugins aren’t what you need. You need a proprietary system that works in realtime or a rendering codec that is hardware supported and that’s probably out of your budget.
    You can work very quickly in Apple’s Motion and LiveType to do the cliché effects you are describing but, unless you are using FCP (and can use the project files instead of the movies), you must render out to the Animation codec, move the file to your editing or composting platform, and render your media again. After Effects and Premiere work the same way (actually much better than FCS2) and you can avoid rendering until the ourput stage.
    > borders that go from static stills to lighted edges, flipping letters, that kind of thing. < > cool texty graphicy stuff you guys tend to use regularly (not to complex, think sega genesis 🙂 ) <
    The selection of text effects presets in AE, Motion, and LT offer cool to cheesy, over the top silly and ultra sophisticated elegance. It’s easy to create your own and save as templates. You don’t need additional plugs to do text. But I’ve never used the Text Anarchy tools for more than a few minutes as a demo. I’d think TA is a more elegant solution than you are seeking.
    Hope you get better advice.
    bogiesan
