Activity › Forums › Apple Final Cut Pro Legacy › Graphic Placement
  • Graphic Placement
    Posted by Cratin Sheffield on January 23, 2009 at 6:49 pm
    Hey everyone,
    I have to place a TV Ratings icon into a program that I am finishing up for PBS. They want the icon to be exactly 52 scan lines high. The show is in 1920 X 1080 HD resolution. How would I place the logo directly at 52 scan lines high?
    John Fishback
    replied 17 years, 8 months ago
    3 Members · 2 Replies
  • David Bogie
    January 24, 2009 at 1:08 pm
    You need an application that will allow you to set or to use precise pixels. FCP doesn’t, AFAIK; there is no “INFO” window that tells you the exact location of your cursor and ther are not grids or rulers/guides. Pity. Using Motion, AE, or Photoshop you can easily create a graphic that fits your 52 line spec. As long as you bring it into FCP at 100%, it won’t change size.
    Does PBS also have on-screen coordinates they want you to use?
    bogiesan
  • John Fishback
    January 25, 2009 at 10:24 pm
    Checkout https://www.digital-heaven.co.uk/dh_legaltext It might help.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
