Activity › Forums › Adobe After Effects › Graphic needs tweaking
Posted by John Mark on May 19, 2014 at 7:28 amHello CC,
I have been trying to create a mock graphic just like the one shown in the image below. Its lacking detail and simple textures and looking to bland. The rectangle and text looks to sharp. I have uploaded my AE file for you to compare and mention what needs to be done in order for it to look the same. The size of the graphic does not matter, only appearance.
AE file – 7510_upload.zip
Thank you for your time.
Stephen Smith replied 12 years, 3 months ago 3 Members · 7 Replies -
John Mark
May 19, 2014 at 11:24 pm[Dave LaRonde] “Now, how do you know the original graphic was NOT nice and crisp-looking?
“You have a point. I guess its the textures missing such as the “light sweep” on the far right of the graphic which I can’t get looking right. And the very soft rounded edges.
Stephen Smith
May 20, 2014 at 2:31 pm -
John Mark
May 20, 2014 at 9:46 pm -
Stephen Smith
May 20, 2014 at 9:56 pmI think that is a great match. I like how you shrunk the size of the logo. You feel it is to bland, I think it is great and that if it is to busy it becomes distracting. If the original one is “too soft” it was most likely because it was originally built for SD and then just made bigger when it needed to fit HD. You want sharp text.
Stephen Smith
Check out my Vimeo page
John Mark
May 20, 2014 at 11:21 pm[Stephen Smith] “I think that is a great match. I like how you shrunk the size of the logo. You feel it is to bland, I think it is great and that if it is to busy it becomes distracting. If the original one is “too soft” it was most likely because it was originally built for SD and then just made bigger when it needed to fit HD. You want sharp text.
“Appreciate the positive feedback! One vital effect missing is the “light sweep” effect, which I can’t get looking right.
See the far right of the graphic.
Michael Szalapski
May 21, 2014 at 11:00 amHave you tried CC Light Sweep?
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Stephen Smith
May 21, 2014 at 2:46 pmWith the CC Light Sweep you’ll need to change the color of the sweep to something darker or darken your Lower Third bar to make the light sweep pop more because your lower third bar is already very light.
Stephen Smith
