Activity Forums Apple Final Cut Pro Legacy graphic is rendering very bad
  • graphic is rendering very bad
    Posted by Nelson May on November 8, 2008 at 7:16 pm
    I made a lower 3rd on photoshop CS3. I made the pixel size pretty large and when I render it and export it in FCP to a .mov file, the graphic is aliased. I have also brought it into after effects and exported as an animation.
    Is there anything I can do to get this graphic to look smooth in FCP? my pixel rate to start in CS3 (for the graphic) is 1000 dpi and I am editing in NTSC DV.
    G5, 1.7, 4MB RAM, 30″cine, G4, 1.6 2MB RAM, Mbox, Neumann TLM-103, FCP HD 5. Pro Tools, Adobe Creative Suite, Reason 3.0, Macromedia Studio, ProAnimator, HVX200 with Firestore v4.0
    Rafael Amador replied 17 years, 10 months ago 3 Members · 4 Replies
  • David Roth weiss
    November 8, 2008 at 7:35 pm
    Nelson,
    The issue is not your graphic, it’s the 4:1:1 color space of the DV codec.
    Go to Sequence >> Settings and change the Quicktime Video Compressor to one of the following codecs with 4:2:2 color space: DV50, ProRes, 8 or 10-bit. Then re-render the timeline and see how much better your graphic looks.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Nelson May
    November 8, 2008 at 8:47 pm
    Will that affect my overall timeline and give any problems when I send it to compressor>
  • David Roth weiss
    November 8, 2008 at 8:58 pm
    [Nelson May] “Will that affect my overall timeline and give any problems when I send it to compressor>”
    Of course not!!!
    Now come on Nelson, see my picture up there on the top, do you think it would be up there for long if I gave out information that caused problems? I solve problems and leave problem creation to others…
    David
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Rafael Amador
    November 9, 2008 at 12:49 am
    [Nelson May] “my pixel rate to start in CS3 (for the graphic) is 1000 dpi and I am editing in NTSC DV.”
    Why are you making 1000 dpi graphics when digital video works with 72 dpi (pixels/inch)?
    If you are working in DV NTSC you only need 720 x 480 graphics, unless you intend to blow them up in FC or AE.
    In Photoshop you have the presets ready when you open a new document. A graphic bigger than the necessary won’t look better. In fact can look much worst.
    This added to the comment of David about DV.
    rafael
    http://www.nagavideo.com
