Activity Forums Adobe Premiere Pro Graphic Importing
  • Graphic Importing
    Posted by Richard Hutt on July 23, 2010 at 6:20 pm
    I have just had Adobe Premiere shoved down my throat after 13 years on an AVID. not happy to say the least. But it is what it is and Im stuck with it.
    We are running CS4 and the problem (one of many) I am having is trying to import graphics cleanly into the system. I have tried PNGs TGAs JPGs and even the native PSD files all to no avail. The JPGS and TGAs come in with no alpha channels yet I am trying to to save them with the transparency. I have always used PNGs in most all of my graphic work and have had no problem. Are there several extra steps (as it seems to be with everything Premeire) that i have to go through to get the graphics in. Any help would be appreciated.
    R
    Richard Hutt replied 16 years ago 2 Members · 5 Replies
  • Vince Becquiot
    July 23, 2010 at 11:18 pm
    Hi Richard,
    First let’s take Jpeg out of the picture, no possible alpha channel in that format.
    Now, as long as your PSD file has an alpha channel or transparency, that should be translated correctly into Premiere. The same goes for PNGs.
    Can you confirm that these are 8 bit RGB files?
    You can also right click on the file in the project panel, choose interpret settings and check that the Alpha channel is not set to ignore.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Richard Hutt
    July 26, 2010 at 6:29 pm
    Hey Vince Thanks for the reply. I can confirm that they are 8 bit RGB files And i checked the interpret settings and nothing is selected there. I dont understand whats going on, its all brand new equipment. And other suggestions?
    R
  • Vince Becquiot
    July 26, 2010 at 6:31 pm
    Hi Richard,
    Can you email me one of those pictures (Vince [at] kaptis.com), or post one of the pictures in question as a file?
    Vince Becquiot
    Kaptis Studios
  • Vince Becquiot
    July 26, 2010 at 6:44 pm
    Richard,
    We are on CS5 here, but there shouldn’t any difference. It imports fine with the logo on the top track, it shows transparency all around.
    Do you mind posting your sequence settings?
    Is the background showing black?
    Vince Becquiot
    Kaptis Studios
  • Richard Hutt
    August 11, 2010 at 2:10 pm
    Vince sorry not to continue with this, i had some vacation planned for the past couple of weeks. Okay back to this…. I will gladly send you the sequence settings, but I’m not sure what that would be or where to find them Again I am very new to this NLE so please don’tt laff at my idiocy!!!
    R
