Activity › Forums › Apple Final Cut Pro Legacy › Graphic for Web video
  • Graphic for Web video
    Posted by Neil Orman on January 23, 2014 at 5:54 pm
    Hello,
    I’m working in FCP7 on a series of videos similar to the sample below, and I need to properly instruct a graphic designer on what I need for a repeatable, tweakable infographic, similar to the one at the start of this video. So if anyone has any quick advice on the brief instructions I should give him, I would certainly appreciate it. There’s a graphic at the beginning of this video, and we need a similar graphic template, one where I can simply change the person’s name and title, without having to ask him to do it each time. My questions include both what is the best format to ask for, as well as the size/resolution I should specify. On the format is it best to ask for an Illustrator file or something else? (I have the Adobe CS4 suite on my system, so I could tweak the template in Illustrator or Photoshop if that helps.) I figured he’d probably send us a PDF, but like I said I need it in a form where I can change the name and title myself, and then if necessary I could convert it myself into whatever format was necessary for a FCP7 timeline. In terms of the resolution it’s for a video to be displayed on Youtube, shot at 720/24PN, at I usually compress it to 1280 X 720 for Youtube. Do I just say I need it at 1280X720. I was particularly confused on this point, because when I check the compressed video file’s dimensions it says 1920 X 1080.
    Here’s that sample video, with the kind of graphic we’re going for:
    https://www.youtube.com/watch?v=MGuEWGIXqI0
    Thanks very much,
    Neil
    Neil Orman replied 12 years, 8 months ago 2 Members · 3 Replies
  • Neil Orman
    January 23, 2014 at 7:49 pm
    Thanks Dave. That sounds like a great approach, in terms of him just creating the background. When you say ‘still,’ I’m assuming you mean he could give me a JPEG, PDF or whatever, or do you think some, like TIFF, are better? Just let me know if you or anyone else thinks the file type matters, and also how high-res or big the file needs to be. Then I guess I’d just lay the text on top of it. And I’d definitely be interested in that fancier text app you mentioned for Final Cut, because when I create text in Final Cut it usually doesn’t look this slick. So just let me know if you come across that info.
    Much appreciated again,
    Neil
  • Mark Suszko
    January 24, 2014 at 9:18 pm
    The “fancier” app is BorisTitle 3D, and you access it from the same button/drop-down menu you use to get the regular text tool.
    The highest quality format you can use for the background “plate” would be a targa or a tiff file, ( .tga or .tif)
    Photoshop .PSD files work as well, and if they can remember to preserve the layers and alpha channel, you can use that as a template and re-type on just the test layer.
    A jpeg is all right if it is of high enough resolution, but only those first three have alpha channel in them.
    .png also has alpha, but it’s not as good as the other ones, IMO.
    if you have the FCP7. Final Cut Suite3, you also have Motion, where you can REALLY make great, fast, video-useable graphics and titlet, and create detailed templates that are fast and easy to update.
  • Neil Orman
    January 26, 2014 at 1:26 pm
    This info is hugely helpful, much appreciated Mark.
