Activity › Forums › Boris FX › Graphic file looks “squashed” in Boris
  • Graphic file looks “squashed” in Boris
    Posted by Lukkee Chong on October 27, 2009 at 1:11 am
    Any explanation welcomed. I have a round logo which becomes oval when I use it in Boris, looks slightly flattened. It works fine in AE CS3.
    Media100 version 13.1 with corresponding Boris for graphics, Photoshop CS3.
    Lukkee Chong replied 16 years, 11 months ago 2 Members · 4 Replies
  • Matt Mullen
    October 27, 2009 at 7:48 pm
    Lukkee,
    What is the original image size and what is the aspect ration of the Red Project?
    In the preferences in Red there is an import tab with options. If you set the Still Import Aspect ratio default to Square pixel do you see any difference?
    -Matt
  • Lukkee Chong
    October 27, 2009 at 8:14 pm
    Hi Matt,
    The graphic file was made “bug” size in a Photoshop 720 x 486 then scaled further in Boris to 92.96. The Boris comp is 720 x 486 4 x 3.
    There is no difference when I select Square Pixel option.
  • Matt Mullen
    October 27, 2009 at 8:17 pm
    Hey Lukkee,
    If you could send me the image I could figure out the correct import settings for you and relay that back to you.
    mattm@borisfx.com
  • Lukkee Chong
    October 27, 2009 at 8:31 pm
    Thanks Matt,
    Will do as soon as it’s rendered 🙂
