Activity › Forums › Adobe After Effects › Graphic equaliser (or whatever it’s called) redux
  • Graphic equaliser (or whatever it’s called) redux
    Posted by Adam Bennett on July 1, 2005 at 9:15 am
    okay – if I want to show the bars of an audio output, I would export the audio to keyframes and then link it somehow to the vertical movement of solids or imported art so they move up and down as the audio gets loud and soft.
    Does anyone know how I would link the keyframes from audio to bars (using expressions perhaps) or if there is a better way?
    Thanks in advance folks!!!
    Jim Dodson replied 21 years, 3 months ago 2 Members · 1 Reply
  • Jim Dodson
    July 2, 2005 at 1:55 am
    Sounds like you might want to apply the effect RENDER –> AUDIO WAVEFORM
    try changing the DISPLAY option to “DIGITAL”
    Also take a look at RENDER –> AUDIO SPECTRUM
    both these make a visual display of the audio on that track so make sure that layer has audio…
