Activity › Forums › Adobe After Effects › Graphic display question
Posted by Marc Lucas on January 24, 2013 at 3:32 pmWhy does AE display solids etc like this, is there a way to get a clean solid edge instead of the kind of transparent edges?
https://dl.dropbox.com/u/2003727/Screen%20Shot%202013-01-24%20at%2015.21.11.jpg
Marc Lucas replied 13 years, 8 months ago 3 Members · 5 Replies -
Vishesh Arora
January 24, 2013 at 3:57 pmMarc
This also happens when you have a Comp with a very small resolution and you are viewing it with a Wrong Zoom Percentage.
See the image below:
Vishesh Arora
3D and Motion Graphics Artist
Films RajendraBlog:
https://digieffects.wordpress.com2011 3D Demo Reel:
https://www.youtube.com/watch?v=lHPgIJU_BR8 -
Marc Lucas
January 24, 2013 at 4:13 pmI get whats happening now. When I select points on the solid layer I didn’t realise it was increasing the scale value opposed to cropping or expanding the actual layer size.
So I assume it is always best practice to make any solid layer the comp size and resize down from that resolution?
Marc Lucas
January 24, 2013 at 4:40 pmI made a solid the comp size and and down sized/scaled and still get those kind of transparent edges
https://dl.dropbox.com/u/2003727/Screen%20Shot%202013-01-24%20at%2016.18.00.jpg
Todd Kopriva
January 24, 2013 at 5:06 pmIf a layer is positioned so that its edge doesn’t exactly align with the boundaries of the pixel grid, then After Effects uses antialiasing along that edge. This makes animation appear smooth when a layer moves. If you don’t want this subpixel interpolation, then you can turn it off for a layer by switching it to Draft mode.
Much more detail is in After Effects Help, here:
“Layer image quality and subpixel positioning”———————————————————————————————————
After Effects team blog
Marc Lucas
January 24, 2013 at 5:22 pmThanks Todd that explains a lot!
I’m on the right track now!
Thanks!!
