Activity Forums Adobe After Effects Graphic Disappearing in After Effects
  • Graphic Disappearing in After Effects
    Posted by Dmossjr on September 5, 2005 at 2:38 pm
    I’m doing a simple 3D 90 degree turn of a graphic. Works find until I put a light on it to cast shadows. When I do that, half of the graphic disappears as it is turning, and doesn’t show up until it has reach full front. I’ve done this effect before, and never had this problem. Help???
    Dmossjr replied 20 years, 12 months ago 3 Members · 6 Replies
  • Andrew Yoole
    September 5, 2005 at 3:23 pm
    If you’re casting shadows onto another layer – a Solid or background of some kind – are you sure the front layer is far enough in front of the back layer not to be passing THROUGH the back layer?
  • Joseph Thomas
    September 5, 2005 at 3:24 pm
    Are all your layers set to 3D with ‘accept lights’ and ‘cast shadows’ in the transform dialogue?
    Joseph
  • Dmossjr
    September 5, 2005 at 8:15 pm
    Hmm…that’s interesting. I guess I didn’t realize it could go through the back layer. It is in front of a solid – and since there are only the three layers (the solid, the graphic & the light) can it go any further in front? Thanks a lot for the response.
  • Dmossjr
    September 5, 2005 at 8:16 pm
    Thanks, Joseph. Yes, all of them are set to receive and cast shadows & light.
  • Andrew Yoole
    September 6, 2005 at 3:20 am
    Move your solid further back in Z space, and adjust it’s scale if necessary to fill the frame. If your rotating object is anchored in its centre, your solid will need to be at least half the width of your object away. So if the rotating object is 400 pixels wide, the solid will need to be at least 200 pixels behind it so they won’t intersect.
  • Dmossjr
    September 6, 2005 at 11:05 am
    Got it. Makes sense. I’ll give it a try – Thanks so much!
