Activity Forums Adobe Premiere Pro Graphic card question
  • Graphic card question
    Posted by Jonathan Shohet on September 19, 2006 at 4:36 pm
    I’m in the process of building a window based system for editing\compositing.
    I’ve noticed that Adobe recommends the Nvidia Quadro cards over the Geforce cards. I am a bit confused. I thought that the advantage of the Quadro is in 3d, while Premiere Pro is more of a 2d software.
    What, if any, reason would I have to buy a much more expensive Quadro card, for editing with Premiere Pro ?
    Payner44 replied 19 years, 11 months ago 3 Members · 5 Replies
  • Blast1
    September 20, 2006 at 8:37 am
    [dixie.fever] “I’ve noticed that Adobe recommends the Nvidia Quadro cards over the Geforce cards. I am a bit confused. I thought that the advantage of the Quadro is in 3d, while Premiere Pro is more of a 2d software”
    The cards that Adobe lists for Ppro 2 is for GPU acceleration for certain effects, they list 6800/7800 chipsets, the newer 7900/7950 cards also work they just haven’t updated their site yet, all these cards are also 3D
  • Jonathan Shohet
    September 20, 2006 at 9:23 pm
    I know Geforce are also 3d cards. I just thought that the only reason to choose a much more expensive workstation 3d card over a gaming 3d card was if you work with 3d programs or use particle effects in After Effects and so on…
    Does anybody know what exactly are the benefits of the Quadro over the Geforce if you mainly use Premiere?
  • Blast1
    September 20, 2006 at 11:41 pm
    [dixie.fever] “Does anybody know what exactly are the benefits of the Quadro over the Geforce if you mainly use Premiere?”
    For normal DV/HDV/HD there is none in particular, as long as the card meets the open GL requirements
  • Jonathan Shohet
    September 21, 2006 at 6:36 am
    thanks 🙂
  • Payner44
    September 22, 2006 at 4:46 pm
    I’m using an inexpensive ATI X1600XT card ($125) with zero issues. I’m doing all HDV stuff with dual 19″ widescreen monitors…DVI to the main monitor and analog (RGB) to the second monitor for watching the timeline in full screen.
