Activity Forums VEGAS Pro Graphic card compatibility for Sony Vegas Platinum
  • Graphic card compatibility for Sony Vegas Platinum
    Posted by Avi Block on May 14, 2015 at 8:42 am
    I am trying to find a graphics card that is compatible and will enable GPU..
    I a have the graphics card Radeon HD 5450 1GB 64bit DDR3 Express 2.1×16 HDCP.
    I was told it is not compatible..
    Help please
    John Rofrano replied 11 years, 3 months ago 4 Members · 4 Replies
  • Norman Black
    May 14, 2015 at 5:37 pm
    AMD 5xxx series cards are certainly compatible. I used to have a 5850.
  • Avi Block
    May 14, 2015 at 5:56 pm
    do you think it would work with a GeForce GTX 555
  • Aaron Star
    May 14, 2015 at 6:18 pm
    Look at the list of AMD cards on wikipedia. Choose a card that is an XT chip, pretty much everything else is not worth your time. Cards like 5700, 7900, 290x should work well and be stable. There is a line in the card versions where MC mp4 encoder does not function gpu anymore. But the Sony AVC encoder will work gpu with all.
  • John Rofrano
    May 14, 2015 at 7:51 pm
    Sony uses OpenCL which has better support on AMD cards so I would recommend any modern AMD card. I have an AMD Radeon HD 7950 and it works great. The only thing it doesn’t work with is accelerating the MainConcept AVC encoder. You’d need to stick with the older HD 5870 for that. Any of the newer cards like the R9 290x or 280x are great GPU’s for Vegas Pro.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
