Activity Forums Adobe After Effects graphic aspect ratio
  • graphic aspect ratio
    Posted by Fred on June 5, 2007 at 11:02 am
    just double checking.
    I was given an animation project from Flash with a document size of 864 x 540. They want a 4:3 video.
    I assume flash works with Square Pixels.
    I export a quicktime from flash at 864 x 540.
    I place the 864 x 540 quicktime file into a 720 x 486 After Effects comp.
    I scale the 864 x 540 quicktime file to 90% inside the 720 x 486 AE comp.
    I render out and use the 720 x 486 AE comp in Final Cut Pro.
    thus
    I get a 720 x 486 4:3 video with the “correct” dimensions of the original graphic artwork that will display correctly on SD NTSC TV.
    That sound right?
    They also said they might want it widescreen. which I would assume would be the 16:9 1280x 720. I know these are the wrong dimensions, but that’s what they created the artwork at. I can export from flash at any size, then squish or crop in After Effects. Any suggestions?
    -Thanks Y’all
    Fred replied 19 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
