Activity Forums Apple Final Cut Pro Legacy Graphic animations Renders issue
  • Graphic animations Renders issue
    Posted by Patrick Aubry on January 21, 2009 at 6:48 pm
    Hi everybody, I have a problem when I import some graphics animations, When I drop them on timeline and playback I see the animation but with some video shift, I don’t know how to explain the issue because my english is not good, but I have checked the animations with QT and it seems to be ok, the animations parameters are:
    1920×1080 – codec animations+ – 30fps
    my sequence is:
    1920×1080 – upperfield – squarepixel – 29,97fps – QT render ProResHQ
    and I have checked with scope, it seems to be ok about luminance and chromo and hue,…
    p.s. the animations plays well in canvas. I use ioHD to playback and the firmware was updated.
    So I don’t have any idea what,s going on ?
    maybe someone can help me
    thank you
    Rafael Amador replied 17 years, 8 months ago 2 Members · 1 Reply
  • Rafael Amador
    January 22, 2009 at 2:23 pm
    Hi Patrick,
    I don’t know if this may be the issue, but you are using 8b stuff wit an 8b Alpha channel in an 10b sequence.
    Animation is old-fashioned.
    You may try the Avid codecs that they support Alpha in 10b and they are free.
    A better solution would be Sheer:
    http://www.bitjazz.com
    The best codec in the world.
    Cheers,
    rafael
    http://www.nagavideo.com
