Graphic and Text problem with FCP 5.04
Sorry in advance for the long winded post. First the back story, I am editing several long form industrials (20 to 50 Min) for a new client, in DV NTSC on their editing system (G5, 2GB RAM, FCP 5.04).
These are existing edits some one else did and I am trying to finish them.The client does editing himself on this system and was complaining that the text created in Title 3D and graphics that were created in Photoshop and Motion looked jagged. He found only good results when he switched the field dominance to none in the sequence settings. He was not viewing the video on an external monitor, so I brought one in.
I created a new sequence and put in text and showed him the text was fine on the external, noting to him the canvas window plays back low res. Thinking I had solved the problem, I went off editing on the existing edits. When I switched the existing edits to lower, the text and graphics on the external monitor suddenly had the jagged edges again. I did several experiments, duplicating the sequence, changing the compressor to DVCPro50 and Uncompressed, still jagged.
So I stayed with the none option selected in the settings and finished the edit. When it came to output on the DVD the graphics and text look fine, but the video played back stuttered in any shot that had a camera move. I tried a couple of options in compressor, changing from bottom and auto field dominance, and the problems were either jagged graphics or stuttered video.
So what am I doing wrong. Is the problem with the graphics (I checked the clip setting and it says it is in an animation codec.) Should they be in a different codec? I am exporting directly from FCP to Compressor.
Don
