Activity › Forums › Apple Final Cut Pro Legacy › Graphic Aliased once rendered!? AHH!!
  • Graphic Aliased once rendered!? AHH!!
    Posted by Ian Smith on July 1, 2008 at 3:53 pm
    I have a simple lower third created from Motion dropped onto the Final Cut timeline. I have 4 total locations that there are lower thirds. The first three look perfect. The fourth lower third graphic (only difference is color) looks great UNTIL I RENDER, and the edges alias like mad! The colors of the first three are gray against black. The fourth graphic is Red against blue.
    What makes things more confusing is: I’ve gotten as far as exporting even though it looks bad on the timeline, and the QTime looks perfect! Ok, this is good… but I need the video to be an FLV, and once I convert it, the FLV looks exactly as it did in my Final Cut timeline when it is aliased!
    How, what, when… I have no more ideas of where the problem lies and I have to push out a draft today! Please suggest! : )
    Thank you!
    Ian Smith replied 18 years, 2 months ago 2 Members · 2 Replies
  • Chris Borjis
    July 1, 2008 at 4:01 pm
    [Ian Smith] “The fourth graphic is Red against blue.”
    pure red can be a problem if chroma levels exceed spec.
    open your vectorscope, park the cursor on that lower third and see if it spikes beyond where it should. bring it down a little with the 3 way cc and it might be ok.
    also what codec are you rendering in your timeline setting?
    DV will totally destroy anything red.
  • Ian Smith
    July 1, 2008 at 7:47 pm
    Thank you for the input!
    I am rendering as DVNTSC 720 X 480, RGB. I’ve also set the rendering to YUV, and SuperWhite… just to try things out. No changes.
    When I export, I use QTime… animation codec, or none compression.
