Activity › Forums › Boris FX Particle Illusion › Graph Keyframe Size
  • Graph Keyframe Size
    Posted by Terry Stephens on October 17, 2012 at 1:58 pm
    Greetings,
    I’d like to enlarge the keyframe button size in the graph window.
    Or find a easier way to select an existing keyframe.
    Because if I’m not very close to the keyframe I want, a left click creates another keyframe.
    I use a programable mouse set to a low (Dots per inch) scale making small movements easy to control but even then I find the keyframe button hard to select.
    Enlarging the button size in the view window was a great help for selecting all the controls.I gotta belive unaware people would appreciate finding out about that one.
    I’m currently running the PI. DEMO version.
    I’m hopefull I’ve missed something!
    Thanks for any input!!!
    Alan Lorence replied 13 years, 11 months ago 2 Members · 1 Reply
  • Alan Lorence
    October 17, 2012 at 6:39 pm
    There’s no way to change the size of the graph window keys unfortunately. You can use the up/down arrows to move between the keys in the current graph, but this doesn’t really help if you want to drag the key positions.
    It *is* useful if you want to delete the key (using the context menu or key shortcut) because the context menu actions work on the currently-selected key — you don’t need to actually r-click on the key.
    You can also use the “n” key to enter a numeric value for the selected key instead of dragging.
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
    http://www.genarts.com
    http://www.wondertouch.com
