Activity Forums Adobe After Effects Graph Editor issue
  • Steve Bentley
    March 28, 2018 at 5:29 am
    Ah welcome to 2018.
    Hit edit/purge All memory and Disk cache
  • Larissa Freitas
    March 28, 2018 at 11:00 pm
    didn’t work
  • Kalleheikki Kannisto
    March 29, 2018 at 12:00 pm
    That’s how it looks when you have two different properties with “show in graph editor” button enabled.
    Senior Graphic Designer
  • Steve Bentley
    March 29, 2018 at 9:57 pm
    Good point K, but still Iarissa should be able to edit them, the only time you run into issues trying to edit different nodes is when their are linked like th X and Y of position before they have been split into discreet channels.
    I didn’t really understand the image supplied ( of the footage, not the graph editor), so I’m not sure what exactly is happeneing there or what the problem is.
    We have exprienced unselected channels showing up in 2018 hence the purge suggestion which fixed it on our end.
