Activity Forums Apple Final Cut Pro Legacy “Grain” removal
  • “Grain” removal
    Posted by Kenneth Peterson on March 21, 2010 at 1:37 pm
    I have a beautiful CU of lead actress with unfortunate “grain” resulting from the Letus lens system used on EX1 w/Nikkor lens not being on / vibrating—ground glass vibrates to “hide’ its texture. So it’s not really a video noise thing, but rather the actual ground glass surface texture. I have read other grain removal posts, but thought maybe there was some thing I might try .
    Any plug ins ???
    Kenneth Peterson replied 16 years, 6 months ago 3 Members · 5 Replies
  • Joel Peregrine
    March 21, 2010 at 3:11 pm
  • Arnie Schlissel
    March 21, 2010 at 3:59 pm
    Grain & noise reduction plugins are designed to deal with moving grain, not the fixed stippling of the ground glass. You may try median filters, but expect this shot to require a lot of work for a marginal benefit.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Kenneth Peterson
    March 21, 2010 at 4:25 pm
    OK makes sense, please explain median filters.
  • Arnie Schlissel
    March 21, 2010 at 8:49 pm
    A median filter is a kind of blur. It looks for “median” values between pixels, and will smooth things out. If you have Shake or Nuke, you can use keys & roto mattes to isolate various areas to apply different levels of blur & median filters.
    Arnie
  • Kenneth Peterson
    March 22, 2010 at 1:01 am
    Thanks Arnie,
    I’ll ck it out
    k
