Activity › Forums › Adobe Premiere Pro › grain on hd
  • grain on hd
    Posted by Dave Hiebert on August 10, 2007 at 4:01 pm
    I’ve noticed on my captured HD footage that there seems to be grain that appears when the camera is doing fairly quick pans. The grain disappears when the pan ends. I heard this was a problem with pro 2.0 but was fixed in CS3. I captured my footage in 2.0 but had to upgrade to CS3 to get the footage to export to tape properly. I still see the grain in CS3 so, I assume that the problem was in the capture from 2.0 and to correct it, I will need to recapture everything. Is that correct?
    I’m pretty sure I already know the answer to this, but i just want to make sure before I redo all the clips…..lol
    Mike Velte replied 19 years, 1 month ago 2 Members · 1 Reply
  • Mike Velte
    August 12, 2007 at 10:12 am
    Experiment with a short capture of the problem area, but I suspect the results will be the same. The problem is a combination of the mpeg codec written to tape by the camera..it lacks frames like DV AND a fast pan which should be avoided with any camera.
