Activity Forums Boris FX Graffiti jaggies in FCP
  • Graffiti jaggies in FCP
    Posted by Bill Ennis on April 21, 2008 at 10:41 pm
    Hi all. Quick question. I’m using Boris Graffiti 5.2 inside FCP 5.1.4. I’m building a simple text graphic over a beveled spline rectangle, which is then keyed over a video clip in FCP. The text looks beautifully antialiased in the Graffiti window. But when I apply it, it shows up with jaggies in FCP.Now, when I view it on my NTSC monitor, the text is rendered smoothly, but this video is only going to be seen on the web, and when I render it out, it remains jagged on my computer screen. Is this just the nature of the beast, or is there something I can do to make my FCP graphic look as smooth as the original Graffiti window?
    Bill Ennis
    Media Magic
    Video Production Services for Business
    since 1984
    http://www.MediaMagic.TV
    Peter Mcauley replied 18 years, 5 months ago 3 Members · 5 Replies
  • John Mecklenborg
    April 22, 2008 at 8:17 pm
    You are going to find compression issues like this when exporting for web. I would try putting a slight gaussian blur (2 to 5 point) over your graphic. For web delivery of SD material it should get rid of some of the mosquitoes and jagged edges.
  • Bill Ennis
    April 22, 2008 at 11:25 pm
    It’s just weird that Graffiti puts a nice smooth antialias on the text in its own window; then as soon as you hit apply and return to FCP, the keyed text shows up jagged. I thought maybe I had some setting discombobulated between Graffiti and FCP that was causing it.
    Bill Ennis
    Media Magic
    since 1984
  • Peter Mcauley
    April 23, 2008 at 5:26 pm
    Hi Bill,
    If you are seeing jaggies in FCP then you most likely are viewing the comp at something other than 100 percent. Try setting the viewer window to 100 percent and see if this resolves the issue. On my machine here, I see the identical looking anti-aliased result on text elements … I have the comp window in RED set to 100 percent and the record monitor in FCP at 100 percent. If I change over to any other size of course, I see jaggies but this is expected and I think it is like this in every application.
    I hope this helps.
    Peter.
  • Bill Ennis
    April 23, 2008 at 10:18 pm
    Thanks, Peter! That was all it was. My confusion came in that, after compressing, the resulting text looked eerily similar to what I was seeing in my FCP Canvas (defaulting to 87%). I made a connection that actually wasn’t there. In outputting to a full res QT movie, the text looks fine. When I compress that, the text seems to take the biggest hit – and looks pretty gnarly. Not sure what I can do about that, since I’m compressing from 1.2GB to 20MB!
    Bill Ennis
    Media Magic
    since 1984
  • Peter Mcauley
    April 24, 2008 at 12:45 am
    Glad to hear that it was something as easy as this Bill.
    Cheers,
    Peter.
